#429750 08/17/19 06:52 PM
Where are the cylinder head numbers on a 1930 194 engine?
wel2
The cylinder head casting numbers for a 1930 Chevrolet are 836273 and 836275.
where are they located on the head?
Look near the top of the picture
Thank you Dave. My head doesn't have any numbers there. I am starting to think it is a 29 head.The temperature gauge hole is not in the back of the head. All my head says is MADE IN USA and C4 MF. What do you think?
My guess is that it is an after market head............
If the temperature gauge hole is located on the driver's side front of the head in the water outlet chamber then it is a 1929 cylinder head.
Just my luck.
I agree with Gene, without the bow tie and Chevrolet part number it must be aftermarket. I looked at 4 more heads and three had part numbers as pictured. The fourth head just has an intertwined C and L in the center.
I meant to ask, a couple of heads had an X cast under the part number. Does anyone know the significance of the X?
thanks
Thanks a lot guys. Is the head worth using on a 30?
I wouldn't. The 1930-31 cylinder head is superior to the 1929 cylinder head.
Do any of you guys have a 30 or 31 head for sale?
The 1930 and 1931 Chevrolets used the same cylinder head since the cylinder head is a two year application.
Here is a picture of the X any ideas what it signifies?
That definitely looks like a Chevy head casting for a 1930-31. My best guess is that the "X" is an indicator of which pattern was used for that casting.
That is a very normal practice in the casting and forging industries when multiple patterns or dies are used. It helped them track the source of problems.
Sometimes an extra letter or symbol is used for parts are are produced for the parts system by either the original supplier or another. Look for the casting date to see if it might be cast a few years later?
The casting dates of the two heads without the X are mid 1930. The heads with the X are both cast in 1931. Maybe something as suggested in a change of pattern but they were pretty good at changing part numbers for changes in parts without a lot of provocation.
