Posts: 60 |
Hello everyone,
I have my 1941 Master Deluxe on the road and running well expect that from time to time it bogs out when the accelerator is pressed about 1/3rd. Based on other feedback I've received here, I suspect the fuel sender is covered in crud of some kind.
Is there any way to access this without dropping the gas tank completely? If I have to drop the tank completely I suppose I should take the opportunity to clean it out in case other gunk is floating around too.
I've also heard that there is a filter sock covering the sender itself and someone suggested that I simply remove that as I have an inline filter in the fuel line. Any thoughts on that?
Thanks!
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I guess you are referring to the fuel outlet on the tank. The fuel sender tells the fuel gauge how much gas there is.
Posts: 60 |
Apologies, yes, I believe you are correct.
Posts: 828 Likes: 6
Posts: 828 Likes: 6 |
You will need to drop the tank there is no sock in a 41. It would be a good time to have the tank cleaned a coated or replace with a new one.
Posts: 373 Likes: 1
Posts: 373 Likes: 1 |
I don't know how much time, money, and effort you are going to put into cleaning the old one, but you can get a nice replacement for about $200 from www.tanksinc.comI used one in a 1948 fleetline and worked fine.
VCCA Member 51121
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
I strongly encourage you to do it right and replace the tank. I am learning that lesson the hard way!
There are plenty of horror stories about problems with cleaning and trying to apply a sealer. I would never consider that.
I personally am very close to replacing the original tank on my '37 Master coupe. I have removed it and had it cleaned twice. The last time was just a year ago. I still get a lot of very fine oxidation particles (rust colored) that plugs the fuel filter about every 750-800 miles. I run non-ethanol gas and use the Stabil 360 in it.
For the cost of cleaning the tank twice I could have a new tank. I was just hoping to keep the original. The exterior looks great because it is not exposed to any weather. Inside is a different story.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Get a new tank. Use 10% ethanol gas. Savings will pay for the tank in no time. Only well heeled folks use straight gasoline with no ethanol or they assume (brain-washed) ethanol is harmful. Remember that the water will separate over time. So drive it now and then. Read the horror stories with a grain of salt. I believe that notion is Just smoke and mirrors for the gullible.  Same with anything over 87 octane. If your car doesn't call for it that's even more money wasted and really is something that will harm your car My opinion. Charlie
Posts: 1,295 Likes: 2
Posts: 1,295 Likes: 2 |
Hello everyone,
Thanks! Since no one has mentioned the bog your having trying to accelerate I would check the the accelerator pump in the carburetor , maybe a rebuild is in order ?
p.k.
Posts: 60 |
Hi P.K., We think alike! I had the carb rebuilt and also put in a brand new fuel pump. Given that it still bogs, the only thing left in the fuel delivery system is, I think, the fuel outlet.
The fuel pick-up in the tank does not have a sock. That was a new feature in 1955.
I had my 38 Master tank restored at the Gas Tank Exchange in Etobicoke. It wasn't cheap but they did a good job. they blasted it inside and out, installed a new outlet and coated it inside and out. I have used it for two years with no problems. http://gastankexchange.com/
