Thanks for the info regarding how the steel trim is attached- I was wondering how it was all put together.
Previous owner of our unrestored '35 Coach covered the roof fabric with a generous coat of aluminum roof coating and extended it over the steel trim onto the roof metal.
I'm in the process of cleaning off the steel trim and the sheet metal and leveling the blisters in the aluminum as much as possible; then will re-seal the steel trim and coat the fabric with black satin Rustoleum.
If we keep this car long enough, I will eventually replace the roof covering
Any other wisdom out there on this process?
