#428835 07/25/19 07:59 PM
ruscar Offline OP
[Linked Image from pic100.picturetrail.com]
216 This screw is just to the left of the fuel pump and just above the oil pan. Must hold something inside the block?
Russell #38868
'48 4 door Fleetline
There is a small metal splash shield inside the block held by 2 screws (one might be inside). It's approx 2"x2" with a curve and it appears to be to deflect oil away from the breather draft tube.
It holds a little deflector in place that is inside ofthe block.It keeps from throwing oil out of the road draft tbe and leaking on the ground.
A new feature for 1936.
ruscar Offline OP
Thanks guys, just didn't remember.
Russell #38868
