YES! Anything that low or lower will cause fuel problems. For best performance the bottom of the pump should be in the neighborhood of 1' above the inlet on the carburetor. You can also have problems if the vacuum tank is too high. It can possibly over power the float and cause flooding. (Any fuel coming out the vent hole on the carburetor is a sign of problems with the inlet valve "float".)
