#428480 07/16/19 11:34 PM
It will not turn over on 6v...it is draggggging???Yes??? Needs rebuilt or replaced????
Johnny Reb
Yes the starter could need rebuilt but you also want to make sure all cables and connections are clean. Are your cables oo or larger? If someone has used the small 12 volt cables that could be your problem.
Yes. 00 cables, I will clean the connections....TY
Johnny Reb
