Will run on idle but backfires and wants to die when accelerated slowly. If you pull down manually on the throttle linkage it will speed up, backfire a little at the carb, run a while then die??? I have ordered a Master Parts List for 1927 but do not have it yet. Does anyone have a diagram view of Carter C-RAJX-O carb????
Johnny Reb
