Posts: 254 |
I'm going to ask a detail question without explaining why, but I may be back with the why if I can't solve my problem. Looking straight down on the distributor cap while standing at the passenger side, with the point nearest the block being 12 o'clock, where should the number 1 wire be?
1937 Master DeLuxe Business Coupe 1954 3100 5-Window 1954 Corvette
Posts: 254 |
Thanks, I won't have a chance to work on it for a few weeks, but the information will be a big help.
Posts: 1,294 |
I always have number one pointing or aiming to number one cylinder. May not be correct but it's the way I do it.
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
Generally most position the No. 1 spark plug wire over the tab on the bottom of the distributor cap or for later vehicle over the trap door on GM.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
JD. I agree but it makes no difference as to clockwise or counterclockwise. The same area on the clockface would be indicated/described either way. Best. Charlie
