My 31 is running lean and likely needs carburetor work. I decided to tune up and check out everything else before reworking the carburetor. I have not found some specs and I would appreciate any info or advice. What pressure should I expect from the fuel pump? What should the manifold vacuum be? Also, what grease should go in the grease pot on the distributor? Do I unscrew it and take it off to add grease? How often should it be turned to feed more grease? Thanks for the help, I am learning as I go. John
Bill Barker has a good site with tons of info for 1931:
1931 Chevrolet here is a blurp from the 1929 Service News, not sure if it is the same or changed for testing the fuel pump on a 31
as for Vacuum
The vacuum on the manifold is measured in inches of mercury, and the vacuum reading should be around 17 to 20 inches of mercury at idle.
grease: use a white cup grease
a white cup grease
Yes, you unscrew the grease cup on the distributor to add grease to the cup.
The lubrication process is explained in your 1931 Owner's Manual.
The Mangy Old Mutt "If It's Not Junk.....It's Not Treasure!"
Thanks, I will go to work!
I am having trouble finding cup grease. If I buy a tube of white lithium grease, is that the same?
