What is the correct stop light bulb for a 1934 tail light The only 6 volt bulbs I can buy here are 6 volt 21 watt single filament bulb.The problem is the bulb is to big and hits the cover lens when I go to fit it.
Also where would I find a Black choke cable. Mine has been cut and is now to short.
Paul, It's a 63, I may have some.
Jon T.
Filling Station has the knobs or the knob and cable for your car.
The cable The Filling Station list on line are with a Brown Knob. I will try them and see if they can supply knob in black.
Cheers Paul.
Hi Jon.Thank for your reply I don't understand the 63 is that the type and pt. no. of the bulb. Do you know what Wattage the bulb is.
Cheers Paul.
63 is the Bulb Number,it's 6 candlepower. Used for several years of Chevies. I do have some.
Jon T.
