#427783 06/29/19 05:41 PM
jmmmn37 Offline OP
Hi,
Can someone help with identifying a Rochester Carburetor? The number stamped on the base is 700 2105. The larger number stamped above that is difficult to read, but looks like KF or KH 29.
I thought this carb would fit my late 235, but the holes in the base are about 1/4" different from the mounting studs.
Any help is greatly appreciated.
Jim
The 7002105 is the throttle body casting number and fits several carbs. From the above hole measurement that is a 216 carb.
jmmmn37 Offline OP
Thanks, Steve; that makes sense, seeing that it doesn't fit the 235.
