Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
I finally found my original clutch disc (my filing system sucks). My thinking was to put it back in the car. The car sat in a barn for almost 30 and it never stuck. I'm still waiting for shop time to open up to get the '38 in and see exactly what the problem is. As it turns out the rivets are showing wear on my original so I'm going to need to get it resurfaced. Do any of you have actual experience with a particular shop that relines clutch discs? There are a lot of outfits that advertise the service but I'd rather use one that has a proven track record. Recommendations??
Posts: 1,255 Likes: 10
Posts: 1,255 Likes: 10 |
If your disc is that old you may have to drill the rivets yourself. Some shops out here in the West won't even let a disc that may be asbestos in the door.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
try Fort Wayne clutch. they ad in lemmings. been re-facing discs and rebuilding pressure plates for my corvettes for near 30 years. mike
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I have not seen a clutch disc that didnt have the facings riveted on. The mdern bonding (gluing) does not allow for the flexing of the fingers between the facings. Tony
Posts: 1,381 |
The Clutch Doctor is the best I have found for quality, service, and price. Trevor 612-801-2250 North Branch, Mn.
