I have a 35 Chevy Standard. I have 8 pieces that I was told went on the front fenders as a gravel shield. I have 2 large pieces that seem to bolt to the lip of the fenders, 2 other pieces that bolt on the back end of the large pieces, 2 long skinny bars that I think go from one side to the other of the fender as 2 holes line up on the lip of the fender but I don't know where the other ends bolt to. Does anyone have a few pics of the way they are bolted together and how they bolt to the car? Thanks, Pete V
I found 2 more pieces. These look like they hook under the lip of the fender because there are 2 holes on the fender that line up with the holes in the end of these brackets but I don't know where the other end bolts up to.
There are no holes to match it up to. Does it Bolt onto the other side of the fender or onto something else? I don't have the fenders on the car right now. It looks like it should connect both sides of the fender to keep it from flapping in the wind.
If 35 is like my 38 there is a brace between the lip of the fender and the radiator support housing but mine a curved to fit close to the fender and clear the wheel. Tony
