#426574 06/04/19 10:16 AM
Hi. I am restoring a 1919 490 which has been stored since 1929, most is in good restorable condition, although the engine was completely worn out. Fortunately I had a rebuilt 490 engine which I will use. Now I have removed the rear axle from underneath the car and a few things are not so good.
The brake actuating parts are heavily worn so have to be made new. When opening the diff the large gear has chips worn off the top of many teeths, the pinion seems OK, though. I counted the gear and it is 11/40, same as the T-Ford. Snyders has new gears, will it fit the 490 diff? I also ordered new wheels from Bill Calimer, the ones on the car were not to be used.
Why am I doing this? I already have a "sister"car to this, came to Sweden both during the summer 1919 and were registered the same week, although in different places. The one rolling is the sole 490 1919 on the road here so with the project restored there will be two, of the 29 said to have come to Sweden after the WW1, there were no Chevys in Sweden before then.
If someone has the brake parts in good useable condition I am interesed to buy.
Olle
Search this user on E-bay, "choppsshopjg". He is in western Canada and lists many early Chev four cylinder parts. He won't respond to requests so if its listed its available. I have purchased a few items from him and the service is good.
I have been restoring a 1918 490 touring. French Lake auto parts in Minnesota has had a transmission on eBay, and may have other parts,also a seller on eBay "metalworker36" has had a lot of 490 parts. Good luck with your project
1917 490, 1928 Depot Hack, 1925 Buick roadster, 1978 Vette pace car, 2002 Z06
