#394046 08/23/17 07:51 AM
wesb Offline OP
Anyone have original top material to identify the pattern?
Wes
Lilhemiram@yahoo.com. 816-547-5006
wesb #394086 08/23/17 10:37 PM
Wes,
The original material was pretty smooth with no linear grain like a Model A or perhaps a Chevy of that age.
It had a very fine texture.
I have the wrong material on my car.
I have seen the good stuff for sale but I don't recall where I saw it.
wesb Offline OP
Hey Mike, thanks for the response. The materials I have samples of are called cobra, tall short random lines, fairly rough and Tuxedo, a random mix of very short lines. Would like to find an original car to verify.
Wes
wesb #426013 05/24/19 11:51 PM
I have an original phaeton top that I can take some pictures of and post. Its black on the top and white on the lower section. I think there's even cotton stuffing in between the fabric?
wesb #426049 05/25/19 11:59 AM
I was told that the Tuxedo was correct for the 35 Chevy. I was told that Hampton Coach/Lebaron Bonny used the same material for the Fords and Chevys and it was a Ford pattern. Nobody really knew I guess and it looked good.
wesb #426059 05/25/19 01:19 PM
I suspect that both Ford and Chevy used the same fabric in original production. Haartz cloth is what I understand to be a reasonable replacement if not 100% accurate. It was as far as I could tell on my 1919 FB Touring. Yes, you have to factor that the existing material has been subjected to dirt, dust, sunlight and other factors that change the appearance.
wesb Offline OP
Hartz made the original material. Still making fabrics 3rd. Generation. Mr Haartz is in charge. I purchased the Tuxedo material.
