Posts: 32 |
Good morning all, I'm certain this will be the first of many posts I will be making here. I might have gone over my head on this one. A friend has asked me to replace the timing gear in his 33 sedan. Iv never done that to this type of car before so I'm going to be asking for a lot of help. First I need to nail down what kind of car I have. So I will start with how do I post photos first so I can show you guys what I have. Then I can move on to how to pull the radiator so I can start the work.A big thanks in advanced for any and all help.
Posts: 32 |
Bill, The tag reads> VIN 3747845 Year 1933
I will order that repair manual, Thank you for help.
Posts: 977 Likes: 7
Posts: 977 Likes: 7 |
Will, the info on the body tag on the engine side of the firewall will have the following information. Post those numbers. STYLE No. BODY No. TRIM No. PAINT No.
Bill Masters
Posts: 32 |
I think these are the numbers your looking for
Job No.33-559 Body No>B10827 Trim> 25 Paint> 752 (maybe) hard to read Body by Fisher
Posts: 977 Likes: 7
It is a 1933 Master 2-door sedan. The body was built in Baltimore, Maryland. I'm at the Area-9 meet in Blue Ridge, Georgia right now, and I can't say what the paint and trim codes are. From where did you find 3747845?
Bill Masters
Posts: 32 |
3747845 Is the VIN number
Posts: 32 |
Bill, Turns out I already have that book. I went clear through it and cant find anything on the cam gear replacement.
Posts: 977 Likes: 7
Where on the car did you find that number? The paint code might be 132, which is black. Trim code 25 is brown mohair.
Bill Masters
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I believe the 33559 model is a four door master sedan. My 32 is model 32559 (four door sedan) and I had a 33 four door and I think the only difference in the model number was the first two (year) digits. It won't make any difference on the engine job as long as it's a master but I suggest you check the engine for casting dates just in case it has had a transplant.
Posts: 977 Likes: 7
Steve, I goofed on the number of doors. You are correct.
Bill Masters
Hey Bill, two or four it won't make any difference on the engine repair. I think the important thing is to be sure the engine is correct for the model.
Posts: 32 |
Where do I find the engine casting numbers?
Right hand side of the block near or behind the starter .
On the older engines it was more in the center ;ower part of the block. As an example the 1933 Master casting number was 837231. Was the same number for 1934.
You guys are correct as usual as I checked on my 32 and it is between the distributor and the fuel pump. Thanks for the correction. Good to know I have back up by the M&N team.
Posts: 32 |
Thanks guys, Here's the numbers I found.
Top number -836915
Middle number -F 28 3
Then next to the bow tie the number 3
