#424086 04/10/19 06:40 AM
Hi anyone know the camshaft thrust plate clearance,or end float measurement for camshaft of 171 1927 chev thanks
As close as you can get it without binding.
devil Agrin
40 years ago I made the mistake of re-using a cam & cam gear (with retaining plate) which had about 20 thou clearance. At idle it would allow the cam to oddly move in/out which would in turn cause the timing to advance/retard enough to create a loping idle that gave everyone fits. A new gear and retaining plate and it ran smooth as could be. Good luck!
