Hi can anyone inform me if I can buy a twin wiper set up to suit a 6volt !934 Chev Coupe. as it gets quite wet in New Zealand most of the Year. It would be nice to have two wiper blades on the car.
Cheers Paul
I guess from the non reply's this wiper is not available. If so what do all you 33,34,35 owners use. I have seen lots of images of 34's with twin wipers, they must be all on 12 volts.
The wood was nothched both sides for right or left driver location. This also allows another vacuum motor to be added. An option at that time was an external mechanical link that tied 2 wipers together for both driver and passenger. I have the option in the box. Has a dummy post.
So there are 3 options to add a wiper. Add an electric motor and control, add another vacuum motor, add a post and tie bar.
Cheers Paul
Speedway Motors engineering in Lincoln NB usa has 6 volt and 12 volt electric wiper motors. They also sell rotary switches to control one or both. They also sell the wiper arms and the blades.
www.speedwaymotors.com/Speedway-Black-12-Volt-Electric-Windshield-Wiper-Motor-Kit,2999.html
mike L
