Terryb Offline OP
Hi there I have had issues trying to identify what my motor is out of and what year it is the casting number for the block is 3970010 not 8 I scrubbed it down to make sure and casting date is J198 but the suffix code is pretty much all gone I need help please
Become a Member!
Terryb Offline OP
And I really don’t want to buy the wrong parts
I quickly found this thread on AACA where they have covered an in depth look at your engine numbers in December. Appears this was a common small block used for 302/327/350 so you need to look at other physical indicators like the stamp pad and other casting numbers on the other engine parts. This looked simple when I first posted and then saw the other post's details. This post might do better if moved to the 1965-1970 Forum on here and hopefully someone has analyzed these numbers previously with the possibility it could be a 1969 302.
The one thing that jumps to mind is your location - this could be a Canadian block so might see some variation or discrepancy on the numbers the guys were tossing around in the below post.
https://forums.aaca.org/topic/320099-what-motor-do-i-have-please-help/
That is only a casting number that means very little What is important is the number STAMPED into the block in front of the right head gasket.
Terryb Offline OP
The suffix code only has a v left on it
