Posts: 412 |
I have been reading previous forums as well as excellent diagrams and info by Bill Barker Skip Gear and Dick Olson regarding engine timing etc relating to 1931. I have a 1932. All info still applies? My distributor is Delco Remy model 633G. The notch seems to be in a different position. If the clips are parallel with the engine (6 and 9 o'clock), then the notch is at about 8 o'clock.
1932 Chev 5 Window Coupe
Yes. My distributor is Delco Remy model 633G. For 1932 your distributor should be a Delco-Remy Model 633J. It is the same distributor as the 633G but the lower end of the distributor body is slightly different.
Posts: 412 |
633G came with the car. But it wasn't running when I bought it. Should work fine?
Posts: 412 |
Thanks JD. Looks like 633G was for 1929-31. It's a Canadian built car. Maybe they were using the 633G to use up old stock? Anyway thanks for the info.
Posts: 88 |
I had a question about the Electrolock. See my post under the general Electrical discussion. Jim G
Jim G
Posts: 1,919 |
If your cars is a Canadian 32, it will have Canadian made Delco parts, the tag will say made in Canada.
