roara Offline OP
Here is another wood Frame Chevy Coupe not sure what year it is! Somewhere between 1925 and 1928 Coupe???
Rory
You might want to post the above in the 1912-1928 forum.
I see two clues that says it is a '28.
1. The engine. You can see the spark plug wires coming out of the rectangle conduit under the rocker cover. Also, the rear push rod cover rib seems to continue from the head into the block, so both head and block are from 1928.
2. The right front brake rods are visible on the chassis. 1928 was the first year for brakes on the front wheels.
;-) Dean
Jim Rodman who makes wood kits think site is Auto Wood restoration in Indiana has exploded wood views of the old chevy's on his site. Also the chevy parts manual has some.
