#421034 02/06/19 06:41 PM
As some of you know I have a 1946 Chevy truck. The Engine is not original and I an having trouble understanding the numbers on it. Any info would be greatly appreciated. The number is CON4 J 121 ...would that be October 12 1951 ?
the numbers you have listed do not ID the engine.
First you need the block casting number. It is on the right lower side of the block and will have 7 raised numbers with the first number being a 7. If it is a later engine the number may be behind the starter.
The other ID is the numbers STAMPED into the horizontlal shelf behind the distributor.
that number came from just below the distributor...i'll see if i can find the others..Thanks
cylinder head casting 3836848
Engine # F1012J
If the last letter is a J the engine is from a 1959-1962 1/2 ton truck
The 3836848 head casting number went from 1956-1962 235 engines.
Thanks chev nut
