Are you refering to casting marks? :confused: If so, according to an article in the G&D, the 1941 casting no. for the engine block is 839400. The cylinder head casting no. is 839401.
I have other information that shows the clutch & flywheel housing casting no. is 839181 and the the cylinder head casting no. is 3835409 for the 14mm spark plug equipped head.
I'm not aware of any cast numbers on either the starter or generator, but there should be oval Delco nameplates on each component showing model number & serial number. The generator model number is 1102667 and the starter is model number 1107033 (first used) and 1107047 (last used).
This information is not from "official" GM / Chevrolet publications - perhaps another VCCA'er can verify it.
If this isn't the info you are refering too, let us know and we'll try to figure out just what you need.
-Bob
