Posts: 27 |
I am pulling down my 32 engine and cant see what retains the camshaft. The service manual is not helpful on this. I have the front cover and sump off and can see that I will draw it out once I understand what retains it.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
You will also need to remove the push rods and followers. There should be a couple holes in the cam gear and if rotated look thru the holes you should see a couple of hex head bolts that retain the thrust plate.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I am not sure they are hex head, I think they may be countersunk head screws but agree on the access through the holes in the cam gear. the shaft wont come out until the followers (lifters) are removed. Tony
Posts: 27 |
