#41939 10/28/02 07:42 PM
need help....can 283 heads be put onto a 350 short block with any problems?????
#41940 10/28/02 09:02 PM
They will bolt right on, but most if not all 283 heads have no provisions for bolt on accy's. Also you could really raise the compresion of a 350 with the smaller CC heads, and the valve size depending on the heads could really restrict your breathing. Why not just use a set of 350 heads? The are fairly common, and you will be assured of no problems. The head casting numbers of the 283 heads also would help with a determination.
John
John
1954 Belair Sport Coupe
1977 Monza Mirage 305 4 Speed
1988 Celebrity Wagon
