Posts: 87 |
Need a recommendation on who can restore a Remy 374A distributor, and can provide cap, rotor and points.
Posts: 3,469 Likes: 48
Posts: 3,469 Likes: 48 |
I might be able to help with the parts. Chipper or JYD might be interested in the restoration. Maybe they will weigh in.
Posts: 87 |
Thanks Mike Please PM me with info on availability and cost
Chevy2550, Does your distributor have a cast iron housing or die-cast? If die-cast a cast iron housing may need to be found as a replacement. Many of the rebuilders or restorers don't have spare parts if any might be needed so my advise is chose wisely. I currently don't have my distributor machine so am not available to help. Skipper (aka JYD) should be able to help.
Posts: 87 |
Thanks Chipper I am not sure I know the difference How is the best way to determine iron housing vs die cast? Magnet?
Posts: 87 |
Cast iron it is Thanks Next step is find parts/rebuild
