Posts: 222 |
I'm attempting to clean up and undo stupid stuff done to my 1960 Corvair sedan by the many former owners. At one time the inside rear window was subject to a terrible job of tinting and when someone removed the dark tint it left a film on the window that resembles wax paper and has defied removing with mineral spirits,heat,razor blade, etc. Any ideas on a way to remove this a lot more then inch by inch. Doing this also puts you in an awkward position to get good access to it. Any suggestions are welcome.Thanks. Ed Bittman VCCA#47508 Dade City,Fl
Posts: 828 Likes: 6
Posts: 828 Likes: 6 |
You might try 3M adhesive remover.
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
If all else fails try acetone. That stuff will even remove gas tank liner.
Posts: 337 Likes: 4
Posts: 337 Likes: 4 |
Try heating a small patch of it with a hair dryer, then take a wool scrubbie and some GooGone and see if it comes off easily.
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I think the tint films of those days was glued with a detergent based solution so the same solution (no pun intended) may well be the answers you are looking for, no guarantees though. Tony
Posts: 311 |
Just so you know acetone is in finger nail polish remover. Be careful it is very flammable! It also takes the heat from your hands quickly when it evaporates, wear gloves.
1932 4 door Special Sedan 1916 490 Touring
Posts: 63 |
I would check with some established window tint shops they should know what would be the best way to solve your problem.
Posts: 2,566 Likes: 14
Posts: 2,566 Likes: 14 |
Easiest thing might be to remove the window so it’s easier to work on. If the car is insured with glass coverage, park it next to a baseball field, wink, wink. Then get a whole new rear window. You didn’t hear that from me.
