#418836 12/14/18 01:46 PM
RonPenn Offline OP
I recently saw a 32 Chevrolet coupe for sale with an 8 volt battery in it. I got to thinking is that a good idea with a 6 volt system? How will generator handle it? I understand they wanted more cranking power for the starter. Any thoughts on this fellas?
1932 4 door Special Sedan 1916 490 Touring
RonPenn #418837 12/14/18 03:00 PM
An 8 volt battery is a poor bandaid for other issues. If you have proper cables and clean connections there's absolutely no valid reason to install an 8 volt battery.
Tiny #418839 12/14/18 03:34 PM
iagree
RonPenn #418847 12/14/18 08:25 PM
There is more than one post out there about 8 volt batteries. It might offer some short term relief. As Tiny stated, it is just a Band-Aid when you really need more than a Band-Aid.
RonPenn #418849 12/14/18 08:58 PM
It helps a little, but could be compared to pissing on a forest fire. To make the car start reliably, the original problem, whatever it was, will need to be fixed. Meanwhile, you go through a lot of bulbs...
bloo #418855 12/15/18 09:48 AM
RonPenn Offline OP
So far everyone has stated my line of thinking when I read about the guy putting an 8 volt battery in a 6 volt car. Not a good idea!
RonPenn #418896 12/16/18 06:44 AM
I dont remember ever seeing a 8v battery down here.
RonPenn #418900 12/16/18 07:44 AM
iagree
Though I wonder if the eight volt battery is enough, by itself, to blow sound bulbs. Aren't they rated at 6-8 volts?
I have no experience with using 8=volt batteries.
Best,
RonPenn #418907 12/16/18 10:01 AM
Charlie,
The higher the voltage the shorter the bulb life. Yes most bulbs are rated 6-8 volts but that does not mean equal life expediency.
RonPenn #418909 12/16/18 10:32 AM
Chipper,
Makes sense to me.
In addition and upon reflection, I suppose the age and condition of the bulb would make a difference, as well.
Thanks for sharing your knowledge with us.
