#418827 12/13/18 11:50 PM
I picked one to put on my 37 p/u and it has a electric clock,my 37 has been converted to 12 volts so the clock will have to be converted but I was wondering if anyone knows if a wind up clock was available for it. I would prefer a wind up so it would not drain the battery and would probably be cheaper to repair then get one converted.
VCCA #45194
Support The VCCA!
Use a 6 volt lantern battery , with a 1 amp fuse to power the clock , will last forever .
A wind up clock, if it existed at all for that car, probably went in the rearview mirror, not the glovebox door.
I got a quote to get it fixed and will do it soon.
VCCA #45194
junk yard jeff
Just FYI.....a lot of truck guys, when interchangeable, use the car glove box door with the clock in place of the trucks original.....some just cut out a hole and use them so if you have some car glove boxes with clocks hang onto them :) ( I think 37 was one of those years but my memory is getting foggy)
1937 Chevy 1/2 ton Pickup
1950 Chevy Styleline Deluxe Coupe
1953 Chevy 1/2 ton Panel Delivery
I'd rather walk and carry a Chevy hubcap than ride in a Ferd.
I have the 36 car glove box door that will bolt in
VCCA #45194
