There's an extensive description on web page <
http://home.znet.com/c1937/Cast.htm>.
37 blocks made in USA have casting numbers under distributor. Canada and all other countries had casting numbers behind starter on block. Casting number for USA = 838101, Canada = 1788201.
The only letters used in 1937 were R for Right Hand Drive Chevys. All Holden bodied Chevys have an R in the stamped serial number. The letter T was used on utility Trucks. (NOT light commercial such as pickups.) All 164 Chevys with Flxible bodies have T in serial numbers. They didn't use other letters till early 1950s.
When you find the date casting, it appears to be bolted to the block with a dome or flat head screw. This tells what shift made the block. A dome and flat would indicate it was made on the swing shift.
Lou
