Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
I am trying to get my brother ready for the Central Meet. He is entering his 70 Impala in the HPOCF Class and the form requires the Engine Identification Number. It has a 350 V-* engine. Thanks for your help and see you down the Back Roads.
Joined VCCA June 1, 1961
Posts: 399 Likes: 1
Posts: 399 Likes: 1 |
Back roads, If you are trying to locate the id number it is located on the passenger side front of the block just underneath the head and valve cover. You probably have an alternator and bracket blocking your vision. It's on a small pad that is stamped. ![stressed stressed](/images/graemlins/default/stressed.gif)
Thanks Steve. See you in Midland down the Back Roads.
