Really a GREAT carb for a driver; of course, you would lose points at a points judged car show
The only downside to the carb is the neopreme diaphragm pump. Try to start the engine sufficiently often that the bowl does not completely dry of fuel. Allowing the bowl to completely dry can cause the neopreme to turn hard if you use ethanol fuel. Once it turns hard, the next step is cracking and failure. Keep it wet, and it will be OK.
Of course, should you ignore that advice, I know where you can get rebuilding kits with new diaphragms.
Jon.
