Posts: 280 |
Does anyone know the initial setting for the idle volume mixture screw (how many turns out from full seat) Carb is also missing power piston spring any one know where I can get one. Thanks John
Posts: 11,162 |
Check out Carbking, you can leave a posting on chevytalk, he shows up there often.
He also visits these forums occasionally.
Posts: 424 Likes: 6
Posts: 424 Likes: 6 |
Setting is dependant on individual unit. We have specs up through and including the 1974 model year. If newer than that, won't have specs.
In the absense of actual specs, a good ballpark approach is to check the taper on the idle mixture control screw. The older short, fat taper would be out 1 to 1 1/2 turns. The newer (about 1972, approximately) long, slender taper (used for more precise adjustment for smog emission), would be from 1 1/2 to 2 1/2 turns.
Jon.
