#41448 04/10/05 11:52 AM
Tomorrow I'm going to check out a '79 Vette that my neighbor's friend as lost interest in restoring --It's in primer w/ all the wimdows out ,doors are off and hood is off. engine is supposedly restored but not run don't know milage . Can anyone point out what I should be looking for and what's miner stuff in this car ??? never delt with a Vette b/4 so really don't know what really to look for . Thanks for your help
john
Wilwood Engineering1955-1957
#41449 04/10/05 01:37 PM
chevmandog, You need to look the windshield header over very closely for signs of corrosion/weakness. Also look the frame over for corrosion and/or rust through, particularity where the outer sidemembers connect with the rear kick up area directly ahead of the rear wheels. If either of those areas are in question, I would steer away from that vehicle. Unless this particular vehicle is something special, running presentable Vetts of that era can be purchased in the 8 to 10 K range these days.
#41450 04/10/05 03:48 PM
It is worth more money if it has the correct orginal engine block. The base engine was option L48 and the optional engine was option L79 (more desirable) Also if it has a factory installed 4-speed transmission that is another bonus. If the car has always been in your area and used as a daily driver for some years do watch out for the rust as Oldie described.
The old quote that you cannot pay too much for a good one or too little for a bad one does apply.
wdoftexas
#41451 04/10/05 04:59 PM
In my area ( the Illinois/Wisconsin border )the "evil " salt on the roads in winter eats car's alive so ,yes rust is a super big factor around here !!!I'll be looking at it as soon as we can get together s/b Monday --maybe Tuesday ---keep your fingers crossed !!!!
john
#41452 04/17/05 05:09 PM
Wdoftexas and Oldie ----Thanks for your advise gentlemen however we looked at the vette yesterday (couldn't get everyone together until Saterday)----WOW !!!! mucho basket cases !!! the "quote" re-built moter is a glob of greese and oil--I can feel cracks in the windshield frame got the feeling it was involved in hit both front and back !!! so we took a pass on it ,look like more truble then it's worth .
john
