Posts: 394 |
I've occasionally had the starter stuck in the flywheel of my "32 coupe. Normally it's no big deal. I simply put the car in gear and rock it back and forth and it frees up. Lately it's happened more often and the last time rocking wouldn't free it. I had to actually take the starter out and put it back in.
I've been told to shim the starter out with a washer on each mounting bolt and that will cure it. What do you guys think? Is this a realistic fix? Is a washer too much or too little?
See the USA in Your Chevrolet
1932 5-Window Coupe 1935 Sedan (streetrod) 1955 Apache 1955 Nomad Two 1956 Nomads 1959 Apache 1964 Malibu SS Convertible 2012 Corvette Grand Sport
James
Posts: 1,294 |
I think a regular washer is to much. See if you can find thin washers or make shims. It sounds like you do not need much.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I would have the starter checked to see if the internal parts are correct and good. With a similar problem on a correct but improperly rebuilt 32 starter the electrical shop found that a shim (spacer/washer) was missing. Once installed it worked as it should. If washers were not required when new then they should not be required now The thrust washer in the nose cone was missing in my starter.
Posts: 2,566 Likes: 14
Posts: 2,566 Likes: 14 |
What is the condition of your ring gear? Mine used to stick but the ring gear has some buggered teeth. I put on a new ring gear on my the new motor I just put in and it it doesn’t stick at all. Same starter.
