Posts: 239 |
I have read the instructions about posting pictures but I must be missing something. I have a sutterfly account. I copied the URL for the picture I want to post and paste it to the" insert image" link. I posts the link but not the picture.
I will probably need the explanation in terms that a simple mind can understand.
Thanks for any help, Pete
1951 styline deluxe sport coupe w/54 engine and power glide
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
That's good input JD. I wasn't aware of that. Piddler you'll have to use the Full Editor then click on the icon that shows a globe with a link of chain across the bottom. When you click that a small box will open with "http://" highlighted. Right click on the http:// and paste the URL of your image in the box and click OK. Another small box will open asking you to name your link. Enter the name for your link and click OK again. The code for your link will appear in your post. Click Preview Reply to make sure everything works the way you want then click Post Reply. When posting a link you need to make sure your hosting account is set to allow public viewing or we won't be able to see it.
Posts: 88 |
There is no such thing as stupid questions. Just stupid answers.
Posts: 239 |
The body tag says it is a 1951 Styeline Deluxe coupe with a gray stripped interior (no other choices) made in Baltimore and the 1993th Deluxe coupe body produced at that fisher Body plant. Can not read the paint number and can not download the serial number....can you post the serial # ?
Posts: 239 |
The serial number is 14JKA 35428 built it Baltimore in January. Paint code is 445
Yes, assembled in Jan. which would agree with the low body number (coupes were not real popular). Color is Fathom Green, a very popular metallic green color. 1951 production began 11-20 of 1950.
