#413583 08/26/18 08:11 PM
I use a battery disconnect when my 37 MD is shut down so when I connect it prior to starting the engine I always pull the light switch to make sure I have a good connection. I had lights two days ago when I started the engine but today the headlights and tail lights were dead. The engine started fine, I have brake lights and dash lights--the fuse looked good but I replaced it just in case, still no lights. According to my literature it could be a bad connection in the light switch--unless I'm missing something. If it is the switch, I'm wondering if I could widen the search to other years in the hope of finding something that could work.
Thrasher
THRASHER #413584 08/26/18 08:17 PM
I think the dash lights prove that the fuse is good. It could be the dimmer switch. Have you tried both upper and lower beams?
old216 #413601 08/27/18 11:14 AM
That idea has not crossed my mind--so I just checked it out and BINGO! That was it! Do you think I should replace it?
Thrasher
THRASHER #413602 08/27/18 11:22 AM
If the dimmer switch is defective.............replace it.
THRASHER #413604 08/27/18 01:38 PM
Sometimes that switch will short and that can be worse. I looked this up a while ago and I think the switch is the same as used in the Chev pickups, well into the fifties. Where I live I can get one of those overnight because there is such a huge market for pickup parts.
old216 #413620 08/27/18 06:33 PM
I'm going to get a new one--thanks again for helping!
Thrasher
