Thank you for the photo, yes that does help. My center bow wood doesn't come down on the metal as far as yours does. Probably to costly to change at this time given I'm not into showing as much as driving but I keep trying to improve it. I would post some pics but I haven't figured out how to make the files small enough to upload.
Email the pictures to yourself and then copy them. The MB or KB will be reduced hopefully enough to be able to post the pictures. Look at the numbers when you send them and then the numbers when you copy them into JPG format.
mike
