dblclh Offline OP
i'm fixin' to install the foot rest for the throttle for my '30 coupe. what is the distance from the throttle post to the bracket bolt hole? of course, i can just fit it to my heal but "correct" might be nice (for a change). thanks, jim
jf lewis
you talking about this guy ?? this is from my 1929
dblclh Offline OP
bear, yes, except my bracket is a rectangle with a 3/8th bolt hole through the lower, overlapped flanges and has two nubbins underneath (i think these are to keep it from swiveling). the foot rest is 2 5/8 x 1 5/8 in. so this is to be bolted through the firewall; i have no half moon metal plate there. how far back from the throttle post do i drill the bolt hole? thanks for the reply, jim
https://www.ebay.com/itm/1926-1927-...p;_from=R40&rt=nc&LH_TitleDesc=0 looks like this, j
jf lewis
The foot rest in question mounts through a metal plate that is attached to the wooden toe board below the firewall like shown on the link that "BearsFan315 " posted above.
here are some shots of mine BEFORE it was mounted to the plate:
Foor Rest Angle
Front of Plate
Some mounted on plate and plate to Toe Board
Front of Board
Back of Board
dblclh Offline OP
thanks for the information. i am goofing with it today, a fun project. jim
jf lewis
