Friend bought a 1923 Stutz 4 cyl Model K firetruck. It had been sitting for 20 years in a shed with dirt floor. Motor was seized but we managed to get it unstuck and running. We oiled the overhead valve train and cyl walls before attepting to start. After running we could see no sign of lubrication coming to the rockers. I am used to Chevs with the oil line coming up to accomplish the oiling. This motor does not seem to have any visible means of oiling. Does anyone know how Stutz oiled their overhead valve system ??
There is not valve cover on a 24 so no gasket. Made it easier to get to but I imagine a mess from the roads of the day. Some of the later four cylinders had covers but I am not sure if they used gaskets.
Dave: Thanks again for responding. Maybe someone with a later 4 cyl will chime in regarding gasket under valve cover if their year uses the the manually self oiling method.
Dick, I don't think so. I could not find any piping or distribution to the top in the catalog and they show a felt pad for retaining oil under the cover. I don't have one so I am not positive. The picture of the engine on the AACA site looks dry. The pockets around the valves on mine are filled with oil. It's too bad he can't round up an owners or service manual.
Great picture of the Stutz. I would never of thought of one as a fire truck, very cool.
I believe the 1925-1928 4 bangers had rocker covers, used the felt pad to retain oil, and had gaskets (although I suspect they were mostly to keep out dirt and dust ).
The lube recommendations from the shop manual says to squirt some engine oil on the rockers every 50 miles, keep the pockets around the valve stems 1/2 full, and squirt some oil on the felt. The rocker arms hitting the felt created an oil mist around the rockers in between oiling.
For myself, I always squirt some oil on the rockers every time I go out for a drive, which is seldom for 50 miles. Just for peace of mind.
Besides, extra oil keeps the outside of the engine nicely lubed. ;-)
Besides what was said above, if there is no well around the springs be sure to oil the valve stem too so the oil travels down the stem. The Chevrolet (at least my 28) head had a cup area at the top of the guide that held a little oil for sealing and lube. Yours may too. I have a 28 head adapted to a brand X car :) and at a car show this seemed to the be the number one question, re the valve oiling. People expected to see a valve cover to keep the oil in the car, but early Chevrolet being a "loss oil system" in regards to valve train oiling stumped a lot of people.
