#41215 01/14/06 11:14 PM
hay chevy guys im restoring a 1967 chevy impala 4dr hrd top. a few years ago i baught a 700r4 tranny for $25.00 im wondering if i will half to shorten the drive shaft. this tranny has a few upgrades. the guy i baught it off of said somthing about the front pump blowing up, so i baught it tore it down everything looked fin. thanks.
gerald and andrews toys
Wilwood Engineering1955-1957
#41216 01/15/06 04:57 PM
Electronic 700R4? computer controlled? :arrow: :arrow: dance Probably will require a special wireing hookup to bypass a computer, and mounts and probably a modified driveshaft. have you tried some of the forums over at chevytalk or classicar? They have guys there that do that weird stuff, like change out modified for original......
#41217 01/15/06 09:08 PM
The 1992 and earlier 700 trannys were not solenoid controlled only the torque converter lockup is wired.The 4L60E is the electric one i have gave thought of putting a 700 in my 63 four door hardtop for distance travel ,at the price of gas an extra two or three miles per gallon would be nice.I think you have to shorten the drive shaft and move the cross member to make it fit.And get the linkage right on the carb or it will blow its insides out.
auto
woody
#41218 01/19/06 09:22 PM
thanks any more thoughts let me know
hi guys we have just got the in a garage and have had some time to get the car up in the air and check things over. we did a mock up of the 700 and we found that a drive shaft out of a b body olds with small yoke fit perfect. the only problem was the cross member. but a easy fix. the other obsticle was the accumlater cover hits the right side floor pan which can be taken care of with a ballpene hammer.
