#411985 07/28/18 04:19 PM
I am installing a hot water heater in my 31 3 window coupe. I am having trouble finding correct fittings for the install.
I am in need of the cylinder head outlet fitting,the lower radiator hose fitting and the toggle electrical switch.
I am aware of the repo switch that was made for a short time but is no longer available.
Any help would be much appreciated.
Thanks for any info.
Randy
Durango, Colorado
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
Lower radiator pipe is FS-455
https://www.fillingstation.com/catalog/flippingbook/index.html#302/z
You need to braze a shutoff valve on to this pipe and then run the heater hose to it.
Bill Barker
(VCCA Member: 9802)
You may want to check with Bruce Deford for the toggle electrical switch. He sold me one many years ago. At the time he was reproducing them.
