Posts: 3 |
I have a 69 Chevy C-10 truck. I just bought a 64 GMC truck for parts. What parts of the 64 can I use on the 69 if any????
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
very few interior/exterior parts will interchange. lots of mechanical pieces will however. what parts did you want to swap out? mike
Posts: 3 |
i want to use the bench out of the 64 if possible. the 69 doesn't have one at all. not sure what else right now. i dont have either one at my house right at the moment. i will keep posting when i get a better look into both. thanks for your help, chris
chris: since the 64 and 69 cabs are significantly different, i'd guess the floorpans to which the bench seat fastens, will also be different. the 64 seat may not be a bolt in afffair but i'm certain you can fabricate the 69 floorpan to accept the 64 seator vice versa. mike
Posts: 3 |
thanks mike, i will try it and see what happens. i will keep you posted.
