Greetings all! Last week I became the proud owner of a 1948 Sedan Delivery, RHD, from South Africa. I'm starting to do some research now and I'm hoping you can help me with information on this car. I was going to call it an export model, but I'm unsure as to how the process worked for GM/Chevrolet in 1948. Was the car completely manufactured here and shipped overseas? I've seen a reference to a General Motors South African Limited plant that assembled vehicles. How much of the vehicle was built there? The VIN tag is located on the upper LH door jamb, not anything at all like the domestic VIN tag. The VIN is XGCFJ184099. Can you decode that for me? Again, very dissimilar to the domestic VIN number. The engine number, while somewhat similar, again is different. It is FAN 339039. I've seen engine numbers that begin with FAA for Flint or FAM for Tonawanda. Where were engines with FAN built? It also does not have the firewall body tag like all domestic Chevrolets. Instead it has a tag that says "CHEVROLET Engine Tune Up Data" and gives spark plug gaps, point clearances and valve clearances. Will try to post some photos of all these things. Looking for any and all help/speculation!
Dale Carter
VCCA #8661
1948 Fleetmaster Convertible
1948 RHD Stylemaster Sedan Delivery
1948 1-Ton Tow Truck
1967 Camaro Coupe
XGC indicates it was assembled in South Africa (XG) and is a Chevrolet (C).
Thx! Is there some reference material that identifies all the outside the US assembly locations??
Dale Carter
VCCA #8661
1967 Camaro Coupe
Good looking truck, Dale. You planning on evening out your drivers arm tanning, or have Janice drive this one, and keep the same sides?
Looks nice Dale. Enjoy!! Bet it will seem strange first several times driving on the roads. Appears not to need major work.
Dick
A fascinating vehicle! I bet it could tell great stories.
I don't have the answers, but I am interested to see what "the numbers" tell us about it!
The engine number FAN 339038, and the Serial # 184099 - those are fairly large numbers. How many were built in South Africa?
Also interesting that the engine prefix letters are FAN, versus domestic US built FAA or FAM. It would seem to imply that the FA matches up, and then the "N" means something else (besides Flint or Tonawanda).??? Where else were engines cast? Or is that final "N" something that would have been on a US cast engine that indicated it was headed overseas - or possibly for a RHD vehicle?
What is the engine casting date by the starter, do you have that?
Chevy Guru
The "N" indicates a right hand drive engine built in Tonawanda.
Gene - Thx for the engine number ID. I haven't studied it a great deal yet, but I do see that the oil breather tube does have a crazy shape to get around the RHD steering box. Did Tonawanda build all the RHD engines? Does anyone know how complete the engines/cars were before they were shipped overseas?
Dale Carter
VCCA #8661
1967 Camaro Coupe
Tonawanda built all export engines. The last letter could be an N or R depending on application.
Knocked down cars were shipped form New York so Tonawanda was a close engine sorce.
It even has an accessory clock and passenger seat.
How did the hook-up the vacuum shfit on the right side?
The transmission and vacuum shift look to be the same as the LHD, all on the left side. The interesting difference is the shift linkage from the steering column on the RH side to get over to the transmission. The shift linkage runs along the firewall behind the engine to a bracket on the firewall on the left hand side. This bracket then serves as the pivot point for the linkage down to the transmission, using it looks like, the same shifter rods as LHD cars.
Do you know if there was a parts book supplement for RHD unique parts??
Dale Carter
VCCA #8661
1967 Camaro Coupe
I have never seen a R.H. parts book. I would suspect they were used in countries where they had R.H. drive.
Thanks, Gene. I've never seen one, but you never know.
Do you have any thoughts on the unusual firewall tag that's there instead of the traditional Fisher Body Tag?? Anyone seen this tag on export cars?
Dale Carter
VCCA #8661
1967 Camaro Coupe
I've always thought RHD parts were listed in the Master Parts Book, along with LHD. That was the way it was done in earlier years, anyway. Look in your Parts Book, and on a given part where R or L matters, I bet you'll see both listed.
Chevy Guru
Sory, they are not even mentioned.
I did see in some 4 Cyl. books R and L listed.
My 1992 Cadillac Parts Book had export model parts listed, but haven't seen anything in the 1940-1953 books I have.
Dale Carter
VCCA #8661
1967 Camaro Coupe
Some Canadian parts lists in the 1930s included both RHD and LHD parts.
The latest one that I have was issued July 1939 for 1937-39 models (Master Parts List No 142).
Tom
Dale... I have a Canadian Parts book for 1946-1957 that I can bring next week if you want to take a look at it. I'm not sure where to look for right hand drive stuff in it...
The way it was structured in the Parts Books in the Teens and Twenties, if there was a part that went both ways, you would simply look up that part.
An effort at an example: Let's say you want a (hypothetical) shift linkage part - you look in that section, and it says:
Shift Linkage, 1940-1948 LHD ...P.N. so and so
Shift Linkage, 1940-1948 RHD ...P.N. different so and so
Chevy Guru
We'll take a look at it next week at the Central Meet in Ontario. Would not expect the Canadian book to reference any RHD parts since, as far as I know, none of their cars were.
Dale Carter
VCCA #8661
1967 Camaro Coupe
A large part of GM Canada production was RHD vehicles for export - complete cars and knock downs. It varied over the years depending on the current import/export tax situations at any point in time but many counties taxed Canadian products lower than other countries so many of the imported RHD cars were from Canada.
Of course some parts of the car could have been imported from the USA to Canada prior to Canada exporting larger pieces of the car so there could be some odd combinations...
Here is a picture of a page from the 1937-39 Canadian master parts list to show typical RHD and LHD listings.
In this time period CKD kits and service parts for many RHD countries were supplied from Canada for favorable tax treatments.
At least through 1939, RHD engines were produced in Canada and the engine serial number had a prefix R.
Later Canadian listings only show domestic (LHD) parts and most of the export sourcing moved to the USA. I expect this was due to tax changes or manufacturing efficiencies for GM.
Tom
Attached PDF document
Vindicated at last! (about the Parts Book lay-out)
I'm wondering what all the letters in the Serial Number tell us.. XGCFJ184099
Headlighter said above the XG denotes Export and South Africa. Does this mean it was shipped knocked down (thus exported) - from US, or from Canada?
Is the FJ just about being a sedan delivery?
Why so many digits following?
Chevy Guru
Well......Thank you Chevy Guru! Of course, the FJ is about the body!! I should have put that together. FJ is the Series designation for the Stylemaster!!
My convertible is a Fleetmaster, which is FK (which was also the Fleetline designation).
I then would have liked to say the next digit was the letter I, which in US cars indicates the month of build, which would be September. However, that digit is definitely a 1, not an I. Maybe just a "typo" or for the export cars they just had the sequence number? Wonder where the plate was stamped, here or in South Africa after it was fully assembled?
The information I have says that there were 191,125 Stylemaster cars produced in 1948, so this could be #184,099.
Dale Carter
VCCA #8661
1967 Camaro Coupe
XG is the plant code so it was assembled in South Africa.
I don't know the source of the "kit" but it was likely from the USA since it has a US produced engine.
Tom
I believe letter F is for 1948 and J is for Stylemaster
dick
