To add a comment, "hot" is a relative term.
At sea level water will boil at 212 degrees. Any increase in altitude will affect the boiling point by reducing it. I have forgotten how much the BP is reduced per thousand in altitude.
Anyway, the engine in our unpressurized old cars will take much more heat without damage than 212 degrees. The problem is in keeping the coolant in when it boils. The overflow devices will work to some extent but may be limited to capacity owing mainly to overfilling the radiator when cool/cold. Heated water expands, as you know.
Best and first thing one to consider is to limit the top tank of the radiator to about no more than half a tank level. I believe Gene has mentioned an inch or so above the flues.
As long as there is coolant in the engine it will not get so hot as to cause any damage. When the water level gets below the water pump impeller then is when the coolant may rapidly cook off and leave your engine with a too hot condition. Head and pistons, etc, suffer then. Pouring in cool/cold coolant may crack the head or block or blow the head gasket. (Best to let the engine cool down and pour coolant in while the engine is idling.) Combustion pressure will then force coolant out at a strong rate depending on how much pressure is forced in the combustion chamber.
Don't sweat a "hot" engine as long as you know the radiator has sufficient coolant and you make a mental note to check the coolant level often and especially after i has run with a temperature needle pegged. Less so, I suppose, if you have an overflow tank.
Okay, you may open fire now.
Charlie
