Posts: 56 |
I think I ran out of gas.It would not fire at all. I added gas in the tank then a little in the carb.. She started right up. But runs bad when wide open. I have noticed that the clear filter between the pump and the carb. is all most empty. I filled the filter with gas and went for a drive now the filter is empty again. Is this bad???
Posts: 30,700 Likes: 141
Posts: 30,700 Likes: 141 |
The bowl will not always be completely full but some fuel should be visable.If vehicle has been sitting for some time I would check -
fuel line for obstructions
dirty "sock" filter in tank
weak fuel pump-both volumn and pressure should be checked
Posts: 56 |
I do not know what was wrong but it caught on fire Sun. I now need a new carb.. It had a Edelbrock 1406 600 cfm on it(never right). What should have been on it? 62 Corvette with 67 impala 327/275 hp.
The 1967 275 horse engine used a Rochester Quadrajet.Will fit (correctly) a 1967 only and will also require the correct intake manifold and air cleaner.(and choke thermostat and rod).Never run any of these engines with out an air cleaner installed---they can back - fire and burn.Thats why the air cleaner is call a filter and flame arrestor.
Posts: 2,576 Likes: 2
Posts: 2,576 Likes: 2 |
why not look around for an AFB if your 62 was a 300 or 340 hp vette or an old WCFB if it was a 250 hp. if it was originaly a 360 hp, the rochester fi unit will be right salty. You'll also need a cast iron intake,( a 62pass car 250 and 300 hp intakes are faily easy to come by.) the aluminum intake found on the 340 hp vettes are a little more difficult to obtain and more costly than its cast iron brothers. good luck, mike
He said he had a 1967 327 engine.The AFB and WCFB would not fit on a 1967 327 Quadrajet intake and the 1962 intake wuold not fit on a 1967 engine (PC valve).
Posts: 56 |
I will have to find out which intake I have and check back.. It had a air filter but burned up in the fire.
any of the 62 intakes will fit a 67 327. all the 67 327's had provision in the block casting to accept a road draft tube and/or the plumbing for a pvc valve whereas the later 327 with large journals lacked machinging on the block in the vicinity of the distributor for a road draft tube/pvc plumbing. regards, mike
Posts: 56 |
Intake # 3875964 GM8 T @B196@ on the front is the fireing order. The holes are two large round in back and two smaller round in front. It had a Edelbrock 1406 on it . And it looks like an adapter for it to bolt to
Posts: 1 |
after help i have a 69 impala and im finding it very hard to source parts from australia . wonder if there are some places you can put me in touch with that might be able to help me over there
Brent with a 69 impala
Posts: 11,162 |
Brent try: RockAuto I haven't ordered from them yet but I liked their online catalog shopping format. After I send and receive an order or two I will post the results HERE.
Posts: 2,157 |
macky, so, did you ever buy through this vendor?.. epi
Posts: 11,162 |
Yes I have ordered several small items, for the 68. hoses etc, I am planning to order some shocks.
2 members (gachap, chevy b),
97
guests, and
19
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,072
Posts429,077
Members18,308
