#406566 04/15/18 09:54 AM
Can anyone shed light on the correct ignition key blank for my 1928 Chevrolet 2 door Coach AB? The ignition key/ column lock is unlocked, but the key is missing, and I was interested in buying some blanks to have a locksmith cut new keys. I found some original blanks with the code 'B17' on them, not sure if they are correct.
Thanks,
Todd
I had the same problem with my ”˜28, locks but no keys for ignition and door.
I tried a newer locksmith with no luck.
So, I took the lock cylinders to the oldest locksmith in downtown Rochester NY. They had the correct blanks and made two new replacement keys within a half hour or so.
.... Ted
