Posts: 1 |
can anyone please post some instructions on pulling the window regulator out of my drivers door? thanks, barry
Acording to shop manual-wind window all the way up,remove inside door handles,remove trim pad -secured with 3 screws, remove 4 screws holding regulator to inner panel, push regulator out of circular opening while holding rear of assembly ,then slide assembly to the notches in the carrier channel and out thru the access hole....I belive that the carrier channel is the channel on the bottom of the glass that the regulator rollers roll in....good luck
They don't mention it in the shop manual but tape the window up to the top of the door before removing regulator. <img border="0" alt="[twix]" title="" src="graemlins/twix.gif" />
