#409173 06/04/18 08:54 PM
I'm in the process of rebuilding a 1933 Master engine that was "schuffled" around on a floor for 51 years. I can see that the oil tubes have been "bent" out of their original shape and will have to be adjusted. I know I have seen the tools that can be used to adjust and aim them, but now that I need them, I can't find the source! I believe some supplier was letting them out on a "loaner" basis, but I need some help in locating that individual. Anyone have a suggestion?
Thanks, Gene
52Conv
Try The Filling Station ------- see the ad right below (or above) this post for the phone number
ken48
VCCA 42589
It is rather easy to make your own tube alignment template fro that engine. Use the oil pan as a guide. bolt a piece of cardboadr or- to the pan and mark where the oil side troughs are. Then mount the cardboard to the engine and aim accordingly.
