#408356 05/21/18 11:30 AM
RonPenn Offline OP
I am going to try and repair the front windshield so it raises up as it is supposed to. Can someone tell me what holds the windshield crank on or does it need to be removed to get header off to get to the mechanism that works the windshield?
1932 4 door Special Sedan 1916 490 Touring
The windshield crank is held in place buy a horseshoe clip which is the same as the clip used on the interior door handles and the window crank handles.
RonPenn Offline OP
I have the tool used to remove the little u clip, worked for over 2 hours ,no luck so far. Any suggestions?
Check to see which way the clip is installed as I believe the tool is made to remove the clip by spreading the legs from the open end.
Chistech did mine, here is a shot of what is under the fabric on the board:
Windshield Board 01
Windshield Board 02
Hope this helps some
I have been taking mine apart with a screwdriver for years. When the clip comes out it is spring loaded and it will pop out as it goes past center. Be ready to catch it or watch where it goes.
is this the Crank Clip used on the handle ??
RonPenn Offline OP
After working all day on repairing the windshield mechanism its working pretty well now. No one told me I didn't have to remove the crank to get the header board off to get to the mechanism ,but live and learn. Everything I read said the windshield should move up 2 to 3 inches, mine only goes up 1 inch before hitting the top. It will let air in and is working ,I am pleased. Thanks for all the help fellas. Ron
Not sure about how high it should rise but from closed when turned to the right you should get five "clicks"to fully raised.
not sure mine opens 2-3 inches, i would say at least 1 inch.
and should be 4 screws holding the board in ??
if the mechanism is bad, you can get a rebuild kit, new gears, and such. had that done to mine. works great now !!
The 1929 and 1930 windshield raises almost three inches. The 1932 windshield only raises about one inch.
